For those of you who use SWE to design control panels, what is your method of communicating wiring to your production departments?
Do you provide wire listings, if so how are you sorting them?
Are you using the new wire label feature in 2014 that labels wire types directly in the schematic?
Do you identify every single wire and its specific connection? If do, how are you handling equipotentials with dozens of wires?
How are you using SWE to speed up the wiring time of your products?
I have my project set up to do equipotential number not wire numbering. We kept losing the wire numbers when we were editing the schematic. Often we are editing schematics after some of the system has been wired, so losing numbers isn't acceptable.
When we do use a panel shop, we turn over a wiring list and schematic. I have the list sorted by location, and then by type. I specify 24V, 24V COM, some AC stuff, and then have a special type called jumpers. Jumpers are just used as logic lines, and I set the formula to be "", so that they won't be numbered.
I very rarely have two wires plugging into the same exact terminal. I have every symbol set up as disconnectable (including terminals) so that I don't have dozens of equipotentials. In the case of a big power distribution block, I don't draw it as one giant symbol with 12 ports or whatever, I draw 12 individual terminal symbols and connect them with my jumper wire type. Here's an example:
We have no interest in doing wire routing in 3d; it becomes much more challenging to do that when you have multiple terminal symbols.
