I am trying to probe my harmonic study results to evaluate the amplification of the model at various points. If I select a Response Graph from the solutions I do not have the option to choose Predefine locations. I added a few workflow sensitive sensors on the assembly but for some reason I do not have an option to select them because Predefined locations is not available. It is difficult to pull the node from the mesh because I adjust the model and re-mesh. Has anyone had this issue, and know why this otion is not active?
Thank you.
Have you set result options to "for specified solution steps" and then chosen "locations for graphs" either as "all tracked data sensors" or "workflow sensative 1"?
This makes the step-by-step results get saved for the sensor. If the results are there then you're able to select the predifined location and actually make the graph.
