File names in the "windows" pull down
Question asked by Sid Humphreys on Mar 27, 2014
Latest reply on Mar 27, 2014 by Rich Chappell
Morning,
I have 2 files.  A part and an assembly.  Both have the same names.  When I have them both in memory and when I want to go between the two files, I go to the "window" pull down menu where all my current files in session can be had and I can pick which file I want to bring into the design window.  When I work on something other than the two files that are named the same but are different by being a prt and an asm, i go to pick one of them.  but they are both labelled as a prt.  I have to pick one.  It comes up and if thats not what I wanted I go get the other.  There is no way by seeing in the window menu which is a part and which is the assembly.  When you hover over the file you want whether it is the part or asm they both display the path with the file name and both ending in prt.  When in reality one is an assembly.
How can I see the correct file suffix so I do not have to shoot for a 50 50 chance each time?
Thank you
Sid
