Hi there,
Because my CAM software won't work with assemblies, I sometimes have to create the fixture for machining as a separate part and then use the "insert part" function to bring the part to be machined into the fixture.
I've now run into a little problem where I've made some minor but significant changes to the original part and I can't figure out a way to get the "fixture part" to update the inserted part per the new specs.
Does anyone know, is there a simple way to do this? I can always re-insert the part but then I have to re-mate it and I recall I had some issues with that.
thanks,
Andy,
I don't understand why the part doesn't update automatically, but I don't use the Insert Part feature. What happens if you edit the Insert Part feature?
Jerry S.
