Two different questions:
1. What's the easiest way to get the name of an open file into clipboard so you can paste it somewhere?
2. Anyone else think it would be handy if you could set the file name in the Custom Property Tab? (A Save-As would occur in the background when you apply the properties.)
Dwight
What I meant was the configuration property manager has a field with the configuration part number-which by default is set to the document name. You can select the text of this field and copy it to the clip board.
