Hello, I am running a design study that is linked to a simulation. This design study is intended to evaluate a mechanism over a range of positions. The end result desired from this study are a list of forces and moments about a specific frame of reference specified by a coordinate system.
I created the simulation and I can get the forces and moments I desire by using the "List Result Force" feature and selecting the frame of reference and vertex for the moment calculations as shown below.
This is all well and good, but I need to do this for a large number of mechanism positions, so I looked into doing a design study so I can do this automatically. This is when my problems start.
I tried setting up a sensor based on the simulation data and couldn't find a sensor type that would give me the moments I need. I could only find a sensor that would give me the free body forces. OK, so then I tried just getting the sensor to give me the forces about the coordinate system I desired. Still no luck! It seems that whatever I do, I cannot get the sensor to give me the forces about a coordinate system.
So, what I ended up doing is scaling back my range of data points and running each simulation manually. Then I wrote down the force and moment values for each simulation. This is not ideal, because it takes time and I had to scale back the number of data points.
My questions are the following:
Is there a way I can get force and moments about a specifed frame of refernce (or force and the location of the center of force) automatically in a design study?
Am I doing something wrong with the sensor configuration in trying to get it to give a specific force about a specified coordinate system? Why it no work?
Should I be looking at another FEA package?
Thanks for your time!
-Paul
does the problem happen on a very simple part? if it does, i would check the soildworks kb. i believe i rememebr this being a limitation. but worst case you could submit the simple file to your reseller to confirm the limitation or if there is a bug.
i think the issue is that you can't get the point in the sensor so you're not getting what you expect. so i'm guessing this is a current limitation. assuming you're working on the current version and service pack?
