5 Replies Latest reply on Apr 23, 2018 12:04 PM by Douglas Saenz
    How to change color of sketch in an Assembly Document using the API
    Marcin Pilat
      Hi,  I have a question that I couldn't find an answer to after days of searching.
      We have an assembly document that has several sketches. It is important to distinguish these sketched by coloring them. In the GUI, this can be easily done either through the Sketch/Curve Color functionality or using the Line Format toolbar. What is the corresponding API to get the same functionality (something that works with C#)?
      When you record a macro of the Sketch/Curve Color functions, nothing is recorded. When you record a macro of the Line Format functions, they appear but the functions used (SetLineStyle, SetLineWidth, SetLineColor) are only defined in PartDoc or DrawingDoc. Running back the macro produces a run-time error 438 "object doesn't support this property or method".
      Any help is greatly appreciated!!
        • Re: How to change color of sketch in an Assembly Document using the API
          Cloud Strife Pom Cloud Strife Pom
          I have a same problem here
          try to use function like IGetMaterialPropertyValues2 to try to apply color in it but it's return -1
            You can use ISketchSegment.color= "int color" but the only problem is you have to edit the sketch to see the changed color
              Douglas Saenz
              I have the same problem and no clues on how to solve it.
                  Simon Turner
                  This works for me:
                  Option Explicit
                  Option Compare Text
                  Dim Part As ModelDoc2
                  Dim boolstatus As Boolean
                      Dim myFeat As Feature
                      Dim mySketch As Sketch
                      Dim mySeg As SketchSegment
                      Dim selMgr As SelectionMgr
                      Dim sa As Variant
                      Dim myConfigs As Variant
                      Dim myMgr As ConfigurationManager
                      Set Part = swApp.ActiveDoc
                      Set selMgr = Part.SelectionManager
                      myConfigs = Part.GetConfigurationNames
                      'Edit the next line so that it selects one of the sketch segments in your sketch:
                      boolstatus = Part.Extension.SelectByID2("Line6@Sketch1@ComponentName-1@AssemblyName", "EXTSKETCHSEGMENT", 0#, 0#, 0#, False, 0, Nothing, 0)
                      Set mySeg = selMgr.GetSelectedObject6(1, -1)
                      Set mySketch = mySeg.GetSketch
                      Set myFeat = mySketch
                      sa = Part.MaterialPropertyValues
                      'Set the next 3 values to the RGB (values range between 0.0 and 1.0):
                      sa(0) = 1.0
                      sa(1) = 0.0
                      sa(2) = 0.0
                      myFeat.SetMaterialPropertyValues2 sa, swInConfigurationOpts_e.swAllConfiguration, myConfigs
                      Part.ClearSelection2 True
                      Part.EditRebuild3
                      Part.GraphicsRedraw2
                      Douglas Saenz
                      This worked for me! I appreciate your help. This is a VB.NET function I wrote to achieve the same:
                              Private Sub ChangeSketchColor(ByVal swModel As ModelDoc2, ByVal sketchName As String,
                                                            ByVal red As Double, ByVal green As Double, ByVal blue As Double, ByRef status As Boolean, ByRef errorMessage As String)
                                  status = False
                                  errorMessage = ""
                                  Dim swSelMgr As SelectionMgr = DirectCast(swModel.SelectionManager, SelectionMgr)
                                  Dim swModelConfigs() As String = DirectCast(swModel.GetConfigurationNames(), String())
                                  Dim boolStatus As Boolean
                                  'Select the sketch
                                  boolStatus = swModel.Extension.SelectByID2(sketchName, "SKETCH", 0.0, 0.0, 0.0, False, 0, Nothing, swSelectOption_e.swSelectOptionDefault)
                                  If Not boolStatus Then
                                      status = False
                                      errorMessage = "Unable to select sketch."
                                  'Get the sketch feature
                                  Dim swFeature As Feature = DirectCast(swSelMgr.GetSelectedObject6(1, -1), Feature)
                                  'Clean up
                                  swModel.ClearSelection2(True)
                                  'Set the color of the sketch
                                  Dim swMaterialPropertyValues() As Double = DirectCast(swModel.MaterialPropertyValues, Double())
                                  swMaterialPropertyValues(0) = red
                                  swMaterialPropertyValues(1) = green
                                  swMaterialPropertyValues(2) = blue
                                  swFeature.SetMaterialPropertyValues2(swMaterialPropertyValues, swInConfigurationOpts_e.swAllConfiguration, swModelConfigs)
                                  status = True
