I teach SolidWorksa at a community college. We are using SolidWorks 2013 eductation/student addition. I can create a Weldment Profile and save it to my own library. I can set the weldment location in the file location option to my weldment profiles file in my library, but I can not get Solidworks to recognize my profiles. What am I doing wrong?
Conrad,
When you saved the profile sketch (.sldlfp file), had you clicked on the sketch in the tree to highlight it prior to saving? If not, then when you try to use the sketch nothing will happen. That's a common mistake. If that's it, open the .sldlfp file, click on the sketch in the tree, then Save, close the file, then try to use it in a Part again.
If that's not it, do you have the correct number of sub-folders in the folder you're pointing to at Tools > Options > System Options > File Locations > Weldment Profiles? So that when you try to use the Structural Shape function you go to the Feature Manager, select from each level, and finally select the specific profile that you want to use from the drop-down.
Please let me know if this works.
