Want to know what type of joints i should define. Practically wleding is done but facing trouble in defining welds. I have attached the image for more clarity.
lots of good discussions in the forum about handling welds
really comes down to what you want to learn in your analysis
most would start with a bonded connection between them
then at the other end of the spectrum, you could model the weld, the heat affected zone, change the material to match that material
there is no right answer, comes down to what level of accuracy you want, assumptions you're ok with..etc
