When I try to render a clear plastic container filled with water I have wierd lines appear (as seen in the attatched photos). I have tried changing the clear plastic material used for the container and that has not made a difference. (I have tried using polyproylene and polycarbonate)
Please could someone help me on how to remove these lines? I have made sure that my scene contains lighting but the problem remains. Also it may be worth noting that a similar (but different) line problem occurs when i dont have water in the container.
With water (polycarbonate and ripple water on maximum).
with still water and polypropylene plastic on good. (the problem was worse on this render).
without water
Hi Rohan,
I see this sometimes happening as well .... In my cases it was always 2 volume bodies next to each other. I usually create a deliberate overlap of the solids of e.g. 0,1mm alternatively you could create a gap between the 2 solids
Maybe this will help you
Regrads
HF
