Sketch Pattern Feature default option needed..
Question asked by Richard Cook on Mar 21, 2014
Latest reply on Mar 21, 2014 by Richard Cook
Not sure if this is exactly the right place but...
When creating a sketch pattern feature in a part document.
If you select a seed point, that is itself a sketch point (in the patern sketch), the feature being patterned is duplicated at the seed point.
I ran into this problem, as a sketch driven pattern feature would not suceed.
I could make a linear pattern feature from the loft cut loft features, but not as a sketch driven pattern.
I found a solution after deleting the seed sketch-point in the sketch used for the pattern.
This was not ideal as now the driving sketch which also used patterns had some under defined sketch points.
I inserted a construction line to define the sketch pattern seed point, so SW would not try to re-create the feature at this position.
(please see the picture, and my thoughts as to a great simple solution for this problem...)
What a pain… I’m sure I am not the only one who has this kind of thing happen to them.
Richard
