8 Replies Latest reply on Mar 24, 2014 12:48 PM by Todd Bennett
    Reorder numbers function
    Todd Bennett
      Does anyone have a function (or snippet) for reordering three variables highest to lowest?
      I have three variables: dimA, dimB, and dimC (all as Double).
      I need them reordered so that dimC is always the smallest number and dimA is always the largest.
      dimA and dimB may be equal as long as they are larger than dimC.
      dimB and dim C may be equal as long as they are smaller than dimA.
      If dimA, dimB, and dimC are all equal, nothing needs to change.
      I made some If, Then, Else statements but there is a bug I couldn't figure out (it has been deleted).
      Todd
        • Re: Reorder numbers function
          Todd Bennett
          This works but it seems clunky.  I wouldn't want to use it with many more variables.
          dim dblA as double
          dim dblB as double
          dim dblC as double
          dim tempA as double
          dim tempB as double
          tempA = dblA
          tempB = dblB
          If dblC > dblB Then
              dblB = dblC
              dblC = tempB
          If dblB > dblA Then
              dblA = dblB
              dim = tempA
          If dblC > dblB Then
              dblC = dblB
              dblB = tempB
            Simon Turner
            Which language?
            .Net (so, c#, VB or even VSTA macros) have access to System.Collections which all have Sort facilities
                  Josh Brady
                  Google "bubble sort"
                      Todd Bennett
                      I looked up "bubble sort" and the improved "selection sort".  There are a few problems.
                      1) I haven't finished my coffee.
                      2) I don't know C++ (or how to convert it to VBA)
                      3) I'm not working with integers.
                      4) I haven't finished my coffee.
                          Simon Turner
                          In VBA, you can use a Collection.
                          Then this article has 2 links to code which sort Collections:
                          http://stackoverflow.com/questions/3587662/how-do-i-sort-a-collection
                              Todd Bennett
                              Here's my fix:
                              Function GnomeSort(ByRef pvarArray As Variant)
                                  Dim i As Long
                                  Dim j As Long
                                  Dim iMin As Long
                                  Dim iMax As Long
                                  Dim varSwap As Variant
                                  iMin = LBound(pvarArray) + 1
                                  iMax = UBound(pvarArray)
                                  i = iMin
                                  j = i + 1
                                  Do While i <= iMax
                                      If pvarArray(i) < pvarArray(i - 1) Then
                                          varSwap = pvarArray(i)
                                          pvarArray(i) = pvarArray(i - 1)
                                          pvarArray(i - 1) = varSwap
                                          If i > iMin Then i = i - 1
                                      Else
                                          i = j
                                          j = j + 1
                                  Loop
                              End Function
                              Private Sub XYZ()
                                  Dim tempVar As Variant
                                  Dim XYZvar(3) As Variant
                                  Set Part = swApp.ActiveDoc
                                  If bPartIsReady = False Or bAssembly = False Then
                                      Corners = Part.GetPartBox(False)
                                      XYZvar(1) = Abs(Corners(3) - Corners(0))
                                      XYZvar(2) = Abs(Corners(5) - Corners(2))
                                      XYZvar(3) = Abs(Corners(4) - Corners(1))
                                      tempVar = GnomeSort(XYZvar)
                                      txtX.Value = Format$(XYZvar(3), "####.000") ' Length is always the longest side
                                      txtY.Value = Format$(XYZvar(2), "####.000") ' Width/height/depth is whatever is not length or thickness
                                      txtZ.Value = Format$(XYZvar(1), "####.000") ' Thickness is always the shortest side
                      Piotr Regula
                      Best way to do this is to assign your values to an array like so:
                      Option Explicit
                      Dim dblA, dblB, dblC, dblTemp As Double
                      Dim dblArray(0 To 2) As Double
                      Dim i, j As Integer
                          dblA = 3
                          dblB = 4
                          dblC = 1
                          dblArray(0) = dblA
                          dblArray(1) = dblB
                          dblArray(2) = dblC
                          For i = 0 To UBound(dblArray)
                              For j = i + 1 To UBound(dblArray)
                                  If dblArray(i) < dblArray(j) Then
                                      dblTemp = dblArray(i)
                                      dblArray(i) = dblArray(j)
                                      dblArray(j) = dblTemp
                              Next j
                          Next i
                          dblA = dblArray(0)
                          dblB = dblArray(1)
                          dblC = dblArray(2)
                      If you want to use more values just change the length of the array
