I need to create a geometry with curved tubes of varying length (see picture). I'm sure there is a way to use any kind of pattern. I tried a linear pattern, but this does not vary the tube length rather than just copy the exact feature. Does anyone know how to use a "smart" pattern?
Bests,
MGG
Thanks to your tip I could solve my problem:
- create two sketches:
a) radius on surface
b) a single circle at the end of the radius curve. use the linear sketch pattern so get multiple circles with a defined distance
- use swept cut. Select b) (group of circles) and a) (radius line). The feature will automatically produce multiple tubes
