How do I make this macro run as a Task?
Question asked by Mike Sveda on Mar 20, 2014
Latest reply on Mar 20, 2014 by Steven Dod
I have no API training.  I am not sure how to modify this macro to run as a task.   I've tried searching help files and no luck.
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim nStart                  As Single
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
    Dim CurFeature              As SldWorks.Feature
    Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A sheet metal part must be open.", swMbWarning, swMbOk
    Exit Sub
' Is it a part document?
Dim modelType As Long
modelType = swModel.GetType
If modelType <> SwConst.swDocPART Then
    Exit Sub
        vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
bShowConfig = swModel.ShowConfiguration2(sConfigName)
bRebuild = swModel.ForceRebuild3(False)
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
Dim StartPos As Integer
Dim FilenameNoExt As String
FilePath = swModel.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
StartPos = InStrRev(FilePath, "\") + 1
FilenameNoExt = Mid(FilePath, StartPos, Len(FilePath) - 5 - StartPos)
'NewFilePath = PathNoExtension + sConfigName & ".DXF"
NewFilePath = "S:\Manufacturing\Cutting Dept\Laser Waterjet Approved DXFs\Sheet Metal DXF\" + FilenameNoExt + sConfigName & ".DXF"
'Export Flat Pattern
bRet = swModel.ExportFlatPatternView(NewFilePath, 1)
Next i
