1 Reply Latest reply on Mar 19, 2014 4:06 PM by Keith Rice
    Export Weldment "Cut List" To A Text File
    Darren Smith
      Can anybody help????
      If I have a weldment (SDLPRT), see the attached part taken from "SolidWorks Samples".
      Can I use a API macro to automatically export a "cut list" to a text file that can be opened with notepad.exe?
      I need the "Part Description", "Length" and "Quantity"
      Any help would be very much appreciated!!!!
      Many thanks in advance.
      Darren
        • Re: Export Weldment "Cut List" To A Text File
          Keith Rice
          Darren,
          This code will get all cut list custom properties:
          Dim swFeat As SldWorks.Feature
          Dim swCustPropMgr As SldWorks.CustomPropertyManager
          Dim vPropNames As Variant, vPropTypes As Variant, vPropValues As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              Set swFeat = swModel.FirstFeature
              While Not swFeat Is Nothing
                  If swFeat.GetTypeName2 = "CutListFolder" Then
                      Set swCustPropMgr = swFeat.CustomPropertyManager
                      swCustPropMgr.GetAll vPropNames, vPropTypes, vPropValues
                      If IsEmpty(vPropNames) = False Then
                          For i = 0 To UBound(vPropNames)
                              Debug.Print swFeat.Name
                              Debug.Print "    Property name: " & vPropNames(i)
                              Debug.Print "    Property types: " & vPropTypes(i)
                              Debug.Print "    Property values: " & vPropValues(i)
                          Next i
                  Set swFeat = swFeat.GetNextFeature
              Wend
          You can modify it as you need to extract particular custom properties. If you want to get the evaluated values then you'll need to use ICustomPropertyManager::Get3 or something like that rather than GetAll, which only gets unevaluated values.
          To export to a text file:
          • In VBA you can use the FileSystemObject. Just google "filesystemobject create text file" and you'll find lots of examples.
          • In .NET you can use StreamWriter. Check this out.
          Keith
          SolidWorks API Video Tutorials
