2 Replies Latest reply on Mar 20, 2014 12:22 AM by Kieu Tran
    Anchor in PropertyManager page
    Kieu Tran
      Hi everyone,
      I want to fixed-left some controls on PropertyManager page when I slide FeatureManager Tree, like image bellow:
      For example code:
              label1 = group1.AddControl(label1ID, 1, "Label:", 1, 7, "")
              label2.Top = 0
              controlType = swPropertyManagerPageControlType_e.swControlType_Combobox
              leftAlign = swPropertyManagerPageControlLeftAlign_e.swControlAlign_LeftEdge
              options = swAddControlOptions_e.swControlOptions_Enabled + swAddControlOptions_e.swControlOptions_Visible
              combo1 = group2.AddControl(combo1ID, controlType, "Type:", leftAlign, options, "Chose Option")
              If Not combo1 Is Nothing Then
                  Dim items() As String = New String() {"First", "Second", "Third", "Fourth"}
                  combo1.Height = 50
                  combo1.Style = swPropMgrPageComboBoxStyle_e.swPropMgrPageComboBoxStyle_EditBoxReadOnly
                  combo1.AddItems(items)
              combo1.Left = 30
              combo1.Top = 0
      Thanks and regards,
      Kieu Tran.
        • Re: Anchor in PropertyManager page
          Artem Taturevych
          Use PropertyManagerPageControl::OptionsForResize and set swControlOptionsOnResize_LockLeft.
          In your case:
          CType(combo1, PropertyManagerPageControl).OptionsForResize = swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockLeft
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Kieu Tran
              Thanks so much, Artem Taturevych! It works.
              But it still have small problem on selection box. Case 2 in the image below:
              And an other problem, case 1. It was be obscured when PropertyManager page dragged. I dont know what happened.
              Here is my code:
                     label2 = group2.AddControl(label2ID, 1, "Type:", 1, 7, "")
                      label2.Top = 0
                      'Combo1
                          Dim items() As String = New String() {"Compliance (Stiffness)", "Natural Frequency", "Displacement", "Strain"}
                          combo1.Height = 50
                      combo1.OptionsForResize = swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockLeft + swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockRight
                      combo1.Left = 30
                      combo1.Top = 0
                      label3 = group2.AddControl(label3ID, 1, "Study:", 1, 7, "")
                      label3.Top = 30
                      'Combo2
                      combo2 = group2.AddControl(combo2ID, controlType, "Study:", leftAlign, options, "Chose Option")
                      combo2.Style = swPropMgrPageComboBoxStyle_e.swPropMgrPageComboBoxStyle_EditBoxReadOnly
                      combo2.OptionsForResize = swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockLeft + swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockRight
                      combo2.Left = 30
                      combo2.Top = 30
                      label4 = group2.AddControl(label4ID, 1, "Parts:", 1, 7, "")
                      label4.Top = 60
                      'Selection2
                      controlType = swPropertyManagerPageControlType_e.swControlType_Selectionbox
                      selection2 = group2.AddControl(selection2ID, controlType, "Select Part:", leftAlign, options, "Solid Bodies")
                      If Not selection2 Is Nothing Then
                          Dim filter() As Integer = New Integer() {swSelectType_e.swSelSOLIDBODIES}
                          selection2.AllowSelectInMultipleBoxes = True
                          selection2.Height = 30
                          selection2.SetSelectionFilters(filter)
                          selection2.SetSelectionColor(True, swUserPreferenceIntegerValue_e.swSystemColorsSelectedItem1)
                      selection2.OptionsForResize = swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockLeft + swPropMgrPageControlOnResizeOptions_e.swControlOptionsOnResize_LockRight
                      selection2.Top = 60
                      selection2.Left = 30
