2 Replies Latest reply on Mar 19, 2014 2:21 AM by Mahadev Dharme
    Query related to applying angle constraint 180 or 360 degree through UI
    Mahadev Dharme
      I have created two sketch lines which are collinear at first. After that, I deleted the collinear constraint without modifying geometry.
      Now I want to add the angular constraint between those lines, but SolidWorks could not able to add that dimension constraint.
      Please find attached snap "180or360AngleIssue.jpg".
      However, if I create two lines which are non collinear, select those lines and now I add the angle 180 degree between those lines, then the angular dimension gets added between those lines.
      Please tell me why the angular constraint could not be applied with geometrically collinear lines, wherein collinear constraint is not present between lines?
      Thanks on advance!
