7 Replies Latest reply on Mar 20, 2014 3:40 AM by Blandine Ganivet
    Insert Ref plane
    Blandine Ganivet
      I would like to insert a reference plane using 3 3D points.
      Here is my code and I don't know why it doesn't work. pleeeaaaase can you help me?
      public void DrawSurface()
                  RefPlane myRefPlane = default(RefPlane);
                  ModelDoc2 swDoc = ((ModelDoc2)(iSwApp.ActiveDoc));
                  swDoc.SketchManager.InsertSketch(false);
                  swDoc.SketchManager.Insert3DSketch(true);
                  SketchPoint SkPoint1 = ((SketchPoint)(swDoc.SketchManager.CreatePoint(2,3,4)));
                  SketchPoint SkPoint2 = ((SketchPoint)(swDoc.SketchManager.CreatePoint(4,1,2)));
                  SketchPoint SkPoint3 = ((SketchPoint)(swDoc.SketchManager.CreatePoint(l1,1,1)));
                  swDoc.SketchManager.Insert3DSketch(false);
                  bool boolstatus;
                  boolstatus = swDoc.Extension.SelectByID2("Point1@Esquisse3D1", "EXTSKETCHPOINT", 2,3,4, true, 0, null, 0);
                  boolstatus = swDoc.Extension.SelectByID2("Point2@Esquisse3D1", "EXTSKETCHPOINT", 4,1,2, true, 1, null, 0);
                  boolstatus = swDoc.Extension.SelectByID2("Point3@Esquisse3D1", "EXTSKETCHPOINT", 1,1,1, true, 2, null, 0);
                  myRefPlane = ((RefPlane)(swDoc.FeatureManager.InsertRefPlane(4, 0, 4, 0, 4, 0)));
        • Re: Insert Ref plane
          Artem Taturevych
          Try avoid using the SelectById2 for selection. In this particular case I think that your points out of the space so cannot be selected. I would recommend using direct selection methods
          Sketch::GetSketchPoints2->SketchPoint::Select4.
          You can also take a look at this method: ModelDoc2::CreatePlaneFixed2 which creates a reference plane by 3 points without a need of creating those points. This method is marked as obsolete but I think it is not obsolete.
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
            Gustavo Oliveira
            Try this code in VBA, unfortunately I can not use C++ at the moment, but you can easily convert.
            Let me know if it helped.
            Good luck
            Dim skPoint1 As SldWorks.SketchPoint
            Dim skPoint2 As SldWorks.SketchPoint
            Dim skPoint3 As SldWorks.SketchPoint
            Dim swRefPlane As SldWorks.RefPlane
            Dim boolstatus As Boolean
                Set swModel = swApp.ActiveDoc
                '' Create 3D Points
                swModel.SketchManager.Insert3DSketch True
                Set skPoint1 = swModel.SketchManager.CreatePoint(0.002, 0.003, 0.004)
                Set skPoint2 = swModel.SketchManager.CreatePoint(0.004, 0.001, 0.002)
                Set skPoint3 = swModel.SketchManager.CreatePoint(0.001, 0.001, 0.001)
                swModel.ClearSelection2 True
                '' Select Points
                '' I prefer this way to select
                boolstatus = skPoint1.Select2(True, 0)
                boolstatus = skPoint2.Select2(True, 1)
                boolstatus = skPoint3.Select2(True, 2)
                '' but you can also use this way if you prefer
                'boolstatus = swModel.Extension.SelectByID2("", "EXTSKETCHPOINT", 0.002, 0.003, 0.004, True, 0, Nothing, 0)
                'boolstatus = swModel.Extension.SelectByID2("", "EXTSKETCHPOINT", 0.004, 0.001, 0.002, True, 1, Nothing, 0)
                'boolstatus = swModel.Extension.SelectByID2("", "EXTSKETCHPOINT", 0.001, 0.001, 0.001, True, 2, Nothing, 0)
                '' Create RefPlane
                Set swRefPlane = swModel.FeatureManager.InsertRefPlane(4, 0, 4, 0, 4, 0)
                Blandine Ganivet
                Thank you for your answer.
                Gustavo Oliveira, I try your way to select the points and now it works!!
                Artem Taturevych, I will try with CreatePlaneFixed2 to make it directly.
                Thanks!!
                    Gustavo Oliveira
                    You're welcome and keep up the good work!
                        Blandine Ganivet
                        I just have a last question How can I get the coordinates of my three points skPoint1, skPoint2, skPoint3 in the plane?
                        Becuse I have to select this point to draw a parallelogram. Do you have any ideas?
                            Gustavo Oliveira
                            You can just use the public properties of the sketchpoint object.
                            Is this what you want to do?
                                Dim x1 As Double
                                Dim y1 As Double
                                Dim z1 As Double
                                Dim x2 As Double
                                Dim y2 As Double
                                Dim z2 As Double
                                Dim x3 As Double
                                Dim y3 As Double
                                Dim z3 As Double
                                '' Point1 Coords
                                x1 = skPoint1.X
                                y1 = skPoint1.Y
                                z1 = skPoint1.Z
                                '' Point2 Coords
                                x2 = skPoint2.X
                                y2 = skPoint2.Y
                                z2 = skPoint2.Z
                                '' Point3 Coords
                                x3 = skPoint3.X
                                y3 = skPoint3.Y
                                z3 = skPoint3.Z
                                Blandine Ganivet
                                What I want to do is a little bit complicated....
                                I want to create a plane with 3 points in 3D. Then I want to do the coordinates of those points but on ths own coordinate system of the plane, of the 2D sketch because I want to draw a parallelogram with those points.
                                I don't know if I am very clear...
                                I want use again the same point but in a 2D sketch.
