AEAbdullah Erdemir17/03/2014
Greetings!
Part is a Solidworks Assembly and Part.EditRebuild3() returns always true.
    Dim swApp As Object
    Dim Part As Object
    Dim boolstatus As Boolean
    Dim topOnly As Boolean
    Set Part = swApp.ActiveDoc
    If Part.EditRebuild3() Then 'This also also always returns true even there is rebuild errors.
        MsgBox "Rebuild successful"  'So the result is always successful but it is not
    Else
        MsgBox "This model has rebuild errors"
   topOnly = True
    If Part.ForceRebuild3(topOnly) Then 'This also always returns true even there is rebuild errors.
        MsgBox "Forced rebuild successful" 'So the result is always successful but it is not
    Else
In API help it should return TRUE when there is no rebuild error. And it should return FALSE when there is rebuild errors. Where am I doing wrong?
Best regards
