Hi all,
I was wondering if there is a way I can automate flow freezing based on convergence criteria, rather than specifying a starting iteration or time step? I'm concerned mainly with concentration decay, and the flow field always converges before the concentration volume goal converges - I'd like to take advantage of this. Ideally, what I'd like to do is run the calculation without freezing until the flow field has converged (P,V,k and E), then enable flow freezing and run until the volume goal for concentration converges. Can this be done?
Dan
Conv criteria is only used to stop the solution.
You'd have to add a loop to your program to spawn a new study with freezing enabled. If that is even possible with the API.
