Hi folks. I'm back with another query
I was creating an animation of my model and its almost complete. Now the designers wants to change the color of a part (actor in composer). I changed the color at few places but the problem is a lot of keys are storing the color property of actors. If I change the color at one key, the next key will bring back the original colr. I've got a ton of keys and updating the color at every key is impossible.
How do I change the color accross whole animation so every key is updated with the new color?
Vipul,
If I had to guess if there is a way it isn't going to be an easy fix since it sounds like you have a lot of "set keys" and they hold all properties of the part. I try to stick to "location keys" as much as possible to avoid this issue some.
I am also interested in this topic. The only way I have found is to change the keys and yes it is a pain. Hopefully someone will be able to tell us a better way.
Derek
