Dear all,
how to add rotating region in an assembly of centrifugal pump.... I have casing and impeller as a assembly file. Should I add rotating region in inpeller's part file of should I make it as a seperate part. Also what should be the average size limit of rotating region which covers the impeller.
I have tried using global rotating region and used real wall cindition. But the solver stops within 10 iterations with a note "solver has stopped......"
mesh size
size of the rotating region part
where it encloses
all of that is in the documentation.
before you go too far. setup and run an analysis of just the impeler part in space and see if you can get things to work, then you can move to your full assembly.
