1 Reply Latest reply on Mar 19, 2014 8:07 PM by Shawn Pantzke
    Is it possible to link revisions to a drawing from a part and also macro problems?
    Brandon Stephan
      I am attempting to redaw several dozen drawings to have a more presentable bank of drawings and to add revisions that need to be noted on all of them. I am trying to incorperate a macro to redraw all of the configurations and have it place them in the appropriate views. I'm also trying to link revisions from the part to the drawing files so when a new revision is added to a part it will automatically insert the revision into the drawings. This would save a lot of time instead of opening every single drawing individually to add the revisions. I am also having a problem with the macro creating every configuration including the flatpattern configuration, I would like it to skip the flatpattern configuration. I also don't know how to tell it to not auto save and exit. I would like to do the choosing to move onto the next drawing. I also heard you can annotate dimensions into the macro aswell. if anyone has any suggestions on my problems I'm open to anything.
      Here is the macro I am trying to work with:
      Dim vConfs As Variant
      Dim i As Integer
      Dim sDrTemplate As String
      Dim lDrSize As Long
      Const sOutputFolder As String = "E:\Drawings\"
          Set swModel = swApp.ActiveDoc
          sDrTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateDrawing)
          lDrSize = swDwgPaperSizes_e.swDwgPaperA0size
          vConfs = swModel.GetConfigurationNames()
          For i = 0 To UBound(vConfs)
              Set swDraw = swApp.NewDocument(sDrTemplate, lDrSize, 0, 0)
              swDraw.Create1stAngleViews2 swModel.GetPathName
              Dim swView As SldWorks.View
              Set swView = swDraw.GetFirstView
              While Not swView Is Nothing
                  swView.ReferencedConfiguration = vConfs(i)
                  Set swView = swView.GetNextView
              Wend
              Dim swDrawModel As SldWorks.ModelDoc2
              Set swDrawModel = swDraw
              swDrawModel.ForceRebuild3 False
              swDraw.InsertModelAnnotations3 swImportModelItemsSource_e.swImportModelItemsFromEntireModel, 32776, True, True, False, False
              swDrawModel.Extension.SaveAs sOutputFolder + swModel.GetTitle() + "_" + vConfs(i) + ".slddrw", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, 0, 0
              swApp.CloseDoc swDrawModel.GetTitle()
          Next
        • Re: Is it possible to link revisions to a drawing from a part and also macro problems?
          Shawn Pantzke
          Brandon,
          I have modified the code that you posted so that it will pull the property from the part to the drawing, assuming that they both have the same property name.
          I have also made it so that it will skip the flat pattern configurations, you may need to tweek this slightly depending on your configuration names.
          Dim i As Integer
          Dim lDrSize As Long
          Dim RevValue As String
          Const FlatIdentifier As String = "flatpattern" 'For skipping flat patterns
          Const Revision As String = "Revision"
          Public Function GetPrpValue(PrpName As String) As String
          Dim swFile                      As Object
          Dim swCustProp                  As CustomPropertyManager
          Dim swModelDocExt               As ModelDocExtension
          Dim bool                        As Boolean
              Set swFile = swApp.ActiveDoc
              Set swModelDocExt = swFile.Extension
              Set swCustProp = swModelDocExt.CustomPropertyManager("")
              bool = swCustProp.Get4(PrpName, False, "", GetPrpValue)
              Set swFile = Nothing
              Set swModelDocExt = Nothing
              Set swCustProp = Nothing
          End Function
          Public Function SetPrpValue(PrpName As String, PrpValue_)
          Dim bool                        As Boolean
              bool = swCustProp.Set(PrpName, PrpValue_)
          End Function
                   RevValue = GetPrpValue(Revision)   'Get part's Revision property
                  If LCase(Right(vConfs(i), Len(FlatIdentifier))) = FlatIdentifier Then GoTo Skip 'Skip flat pattern configurations
                  Wend
                   SetPrpValue Revision, RevValue 'set revision property in drawing file to match part file
              'this is the portion of the code that saves and closes the files
          Skip:
              Next
