3 Replies Latest reply on Mar 18, 2014 7:50 PM by Gustavo Oliveira
    Select edges of a part
    Hesamoddin Yavari
      Hi
      I was wondering if any one can tell me how I can select only the top edges of the part below to do fillet.
      Part of the code that I wrote is as below, but it does not work.
      Dim swBody As SldWorks.Body2
      Dim vEdges As Variant
      Dim swEdge As SldWorks.Edge
      Set swPart = swModel
      Set swBody = swPart.Body
      vEdges = swBody.GetEdges()
      Set swEdge = vEdges(???)
      swEdge.Select2 True, Nothing
      Regards
      Hesam
        • Re: Select edges of a part
          Gustavo Oliveira
          Try this:
          Dim vBodies As Variant
          Dim vBody As Variant
          Dim vEdge As Variant
          Dim swFeature As SldWorks.Feature
          Dim swRefPlane As SldWorks.RefPlane
          Dim swEntity As SldWorks.Entity
          Dim distance As Double
              Set swModel = swApp.ActiveDoc
              'Clear selection
              swPart.ClearSelection2 True
              'Get Front Plane Object
              Set swFeature = swPart.FeatureByName("FRONT")
              Set swRefPlane = swFeature.GetSpecificFeature2
              'Get Bodies
              vBodies = swPart.GetBodies(0)
              For Each vBody In vBodies
                  'Get Body
                  Set swBody = vBody
                  'Get Edges
                  For Each vEdge In vEdges
                      'Get Edge
                      Set swEdge = vEdge
                      'Check if is the top edge
                      distance = swModel.ClosestDistance(swEdge, swRefPlane, Nothing, Nothing)
                      If distance > 0 Then
                          'Select Edge
                          Set swEntity = swEdge
                          swEntity.Select True
                  Next
                  'Create Fillet
                  swModel.FeatureManager.FeatureFillet 195, 0.001, 0, 0, 0, 0, 0
              Next
