I have been working on my helmet a while now, I got advice from others on this forum to do surface modeling instead of a lot of extruded cuts. It looks good, but all I need it to cut a few things out. I made a closed figure on a plane adjacent to the front plane, but all of my "cut" options are greyed out. Could someone help me and explain what they did?
You need to convert the surface into solid body using the knit surface option (and selecting "try to form solid"). Then only you would get the cut options. You can also try the trim tool in the surfacing though.
Looked quickly at your model and there is some gaps which is not allowing it become solid while doing knit.
