4 Replies Latest reply on Jan 13, 2015 10:07 AM by Has Bal
    View Poisition issue
    Hersh Sridhar Iyer
      I am querying view locations in order to modify it at a later point. The API documentation says that the Position Property - "
      Gets and sets the X and Y location of the drawing view origin with respect to the drawing sheet origin."
      When I run the macro provided with the api to query for view locations, I get negative co-ordinates too. Is this possible? Is the sheet origin not at the lower Left corner?
      Also, when I set the location of a view to (0,0), it is set way below the drawing and not at the lower left.
      Please advise.
        • Re: View Poisition issue
          Hersh Sridhar Iyer
          Here is the code I use to set the position to (0,0) for the second view.
          The result of doing so is seen in the attached drawing.
          Dim swApp As Object
          Option Explicit
              Dim swModel                     As SldWorks.ModelDoc2
              Dim swDraw                      As SldWorks.DrawingDoc
              Dim swView                      As SldWorks.View
              Dim vPos()                      As Variant
              Dim nNumView                    As Long
              Dim bRet                        As Boolean
              Set swModel = swApp.ActiveDoc
              Set swDraw = swModel
              nNumView = 0
              Set swView = swDraw.GetFirstView
              Do While Not swView Is Nothing
                  ReDim Preserve vOutline(nNumView)
                  ReDim Preserve vPos(nNumView)
                  vOutline(nNumView) = swView.GetOutline
                  vPos(nNumView) = swView.Position
                  Debug.Print "View = " + swView.GetName2
                  Debug.Print "  Pos = (" & vPos(nNumView)(0) & ", " & vPos(nNumView)(1) & ") mm"
                  If nNumView = 2 Then
                      vPos(0) = 0
                      vPos(1) = 0
                      swView.Position = vPos
                      Exit Do
                  nNumView = nNumView + 1
                   Set swView = swView.GetNextView
              Daniel Seaman
              Hello Hersh,
              The problem you are seeing with then drawing you posted to the forum is that the Position of the detail view is outside of its Outline by some distance.
              If we calculate the centre of the Outline and compare it to the Position it becomes clear why the detail view is moved off the sheet:
              Drawing View1X or X MinY or Y minX maxY max
              Outline Centre0.4019370.358226
              Detail View BX or X MinY or Y minX maxY max
              Outline Centre0.3592950.134110
              Notice that the Position of DrawingView1 is located at the centre of its Outline while the Position of Detail View B is above and right of the outline.
              This is because the Position of Detail View B is in the same location relative to the geometry shown as the Position of is parent view once you take the different scales into account (20:5).
              To compensate for this you need calculate the offset from the view Position to the Outline centre and apply that to your new position.
              Applying this to your macro code would result in something like this:
                          ' Calculate centre of outline
                          Dim dViewCentre(0 To 1) As Double
                          dViewCentre(0) = vOutline(2)(0) + (vOutline(2)(2) - vOutline(2)(0)) / 2
                          dViewCentre(1) = vOutline(2)(1) + (vOutline(2)(3) - vOutline(2)(1)) / 2
                          ' Calculate offset from position to centre
                          Dim dPositionOffset(0 To 1) As Double
                          dPositionOffset(0) = vPos(2)(0) - dViewCentre(0)
                          dPositionOffset(1) = vPos(2)(1) - dViewCentre(1)
                          ' Define the location you want the view centred on.
                          Dim requiredViewCentre(0 To 1) As Double
                          requiredViewCentre(0) = 0  ' X distance from bottom left in metres
                          requiredViewCentre(1) = 0 ' Y distance from bottom left in metres
                          ' Apply the offset to determine the new position
                          Dim dNewPos(0 To 1) As Double
                          dNewPos(0) = requiredViewCentre(0) + dPositionOffset(0)
                          dNewPos(1) = requiredViewCentre(1) + dPositionOffset(1)
                          swView.Position = dNewPos
                          Exit Do
              Best regards,
              Dan Seaman
              SW API Support
