0 Replies Latest reply on Mar 12, 2014 9:57 AM by Jens Moens
    Solidworks macro doesn't run from stand alone .exe
    Jens Moens
      Hi everyone,
      Because I haven’t found a solution on the forums, I’ve decided to post this problem here:
      As a part of my master’s thesis I want to automate a solidworks macro from outside SW. For this I have created a VB.net application (.exe). To start from, I’ve used the example macro found on this website.
      When I run this macro inside solidworks, there is no problem, everything runs as it should.
      But when I run the same macro through the stand alone .exe, SW gives an error : run-time error ‘9”, Subscript out of range ( on the namesCount-line) He doesn’t count the number of files in the assembly for some reason.
      The strange thing is, if I  start my computer, the first time I run the macro from the .exe, it works, but after that the error appears.
      Is there someone who knows the cause and hopefully a solution to this problem?
      SW-macro code:
      ' Open assembly
      openFile = "C:\Program Files\SolidWorksCorp\SolidWorks\samples\tutorial\advdrawings\handle.sldasm"
      Set swModelDoc = swApp.OpenDoc6(openFile, swDocASSEMBLY, swOpenDocOptions_Silent, "", errors, warnings)
      Set swModelDocExt = swModelDoc.Extension
      ' Get Pack and Go object
      Debug.Print "Pack and Go"
      Set swPackAndGo = swModelDocExt.GetPackAndGo
      ' Get number of documents in assembly
      namesCount = swPackAndGo.GetDocumentNamesCount()
      VB.net (.exe)
      Module Module1
          Sub Main()
              Dim app As SldWorks = CreateObject("SldWorks.Application")
              Dim mySolidworks() As Process
              mySolidworks = Process.GetProcessesByName("SLDWORKS")
              If app IsNot Nothing Then
                  app.Visible = False
                  app.RunMacro("C:\source\MHT-macro.swp", "Module150214", "main")
                  'may have to kill SolidWorks
                  app.CloseAllDocuments(True)
                  app.ExitApp()
                  Try
                      mySolidworks(0).Kill()
                  Catch ex As Exception
                  End Try
      End Module
