Hi all,
As you can see, I am trying to create cable conductors.
Obviously, I am having an issue with SWX 2013 Lofting.
I am accustomed to creating a 3D curve with endpoint tangency/curvature/normal options, then creating a sweep
or swept blend that allows me to specify the cross-sections orientation to the trajectory.
In this case, It would be normal to trajectory in order to avoid the flattening of the shape.
Any suggestions?
Thanks in advance,
fred
Fred,
For the case you've shown, where you have cylindrical sections on either end that you are joining together, you should be able to use the temporary axes of the cylinders. Make a 3D spline that is reasonably close to tangent to the temporary axes and then add the Tangent relation to each end.
Jerry S.
