I am attempting to create a NACA 2412 airfoil using the coordinates given by the generation found here. I have added in the Z coordinates=0 (as well as the stuff at the top) however the function in Solidworks is not specific enough to plot all of the points. Plot a curve through XYZ points will automatically shorten the points to the hundredths place. The problem with this is that the majority of the points for the airfoil are only different from the thousandths place on.
Is there any way I can force Solidworks to recognize all of the digits?
Thanks!
Hi
Even if you do not see any decimal places, Solidworks uses them. Try to set the Document Properties-Units to more decimal places and you will see them
