2 Replies Latest reply on Mar 11, 2014 9:00 AM by Kevin Pymm
    Using SW for designing packaging
    Mark Wilson
      Greetings All,
      I was wondering if SW can be used to determine how many parts can be packed in a given sized carton. The parts will be models, but most of the time they're bulk packed. That means they're just dumped into a box in a random manner, and not laid out in order. Ideally, I'd like to make up a library of the carton sizes that we stock. That's the easy part. Can SW simulate a bunch of modeled parts (all of which are the same) randomly falling into a carton so I can determine how many will fit? TIA, Mark
        • Re: Using SW for designing packaging
          Jeff Holliday
          This has been asked a few years ago and the basic answer was that it is not possible. You can certainly use the mass properties (volume, etc) to find how many would fit in a stacked master carton, but I don't know how you could account for lost space caused by tilted boxes. It becomes even worse if you are just putting odd-shaped parts into the carton.
            Kevin Pymm
            Mark,
            The only way I know of is to export your Solidworks part & take it into Blender which is free modelling software. You'd need to read up on some tutorials but I believe it can be done by makeing your part a particle & dropping them into a container.
