2 Replies Latest reply on Mar 10, 2014 8:23 AM by Atte Peltola
    Traversing thru Assembly
    Atte Peltola
      Hi all,
      I am fairly new with Solidworks API. Mostly I have been in forums and API Help to copy paste macro's and combining those for my needs. In below macro I traverse thru an Assembly and my purpose is to choose only SW parts(I want to do more but just for testing). I I get this to work with sub assemblies(swDocASSEMBLY) but with parts(swDocPART) debugger just prints top level assembly. Could anyone help me to understand why it does not work?
      Option Explicit
        Dim swApp                  As SldWorks.SldWorks
        Dim swModel               As SldWorks.ModelDoc2
        Dim swConfigMgr        As SldWorks.ConfigurationManager
        Dim swAssy                 As SldWorks.AssemblyDoc
        Dim swConf                 As SldWorks.Configuration
        Dim swRootComp       As SldWorks.Component2
        Set swModel = swApp.ActiveDoc
        Set swConfigMgr = swModel.ConfigurationManager
        Set swConf = swConfigMgr.ActiveConfiguration
        Set swRootComp = swConf.GetRootComponent3(True)
        TraverseComponent swRootComp, 1
      Sub TraverseComponent(swComp As SldWorks.Component2, _
        nLevel As Long)
        Dim vChildComp                  As Variant
        Dim swChildComp                 As SldWorks.Component2
        Dim swCompConfig                As SldWorks.Configuration
        Dim i                           As Long
        Dim bRet                        As Boolean
        Dim swCompModel                 As SldWorks.ModelDoc2
        vChildComp = swComp.GetChildren
        For i = 0 To UBound(vChildComp)
          Set swChildComp = vChildComp(i)
          Set swCompModel = swComp.GetModelDoc2
              If swCompModel.GetType = swDocPART Then
              'If swCompModel.GetType = swDocASSEMBLY Then
                      Debug.Print "Component: " & swComp.Name2
                      bRet = swComp.Select4(True, Nothing, True)
          TraverseComponent swChildComp, nLevel + 1
        Next i
        • Re: Traversing thru Assembly
          Artem Taturevych
          Your second function should look like this:
            nLevel As Long)
            Dim i                           As Long
            Dim bRet                        As Boolean
              If swCompModel.GetType() = swDocPART Then
              Next i
