Can anyone tell me how do I create the cut with a bend as highlighted in the image I uploaded?
Second image shows the part that I want to cut in.
It looks to me like you need a Swept-Cut. Create two sketches, one for the profile of the cut and another for the path for it to follow,
I tried that but it didn't work. Where the two lines meet, the cuts meet at a 45 deg angle and its not smooth (see image 1). And if i fillet the line that just doesnt connect the two cuts. Infact it cuts away everything leaving only two discs at the end points.
Is ther some other property I have to define in the swept cut feature?
https://forum.solidworks.com/message/414474#414474
Sweep path at inside edge of profile bend and add tiny radius (well within realistic manufacturing process).
If you can't figure it out - attach your *.sldprt file here.
Vipul,
Your swept cut should work
Modify both sketches
Your guide curve corner rad should be the same rad of your profile
See below
