9 Replies Latest reply on Jan 6, 2017 10:33 AM by Cad Admin
    Macro to delete BOM
    Shivbhadrasinh Gohil
      Hello all,
      Is there any macro that will delete existing BOM from drawing ?
      If there is something please share.....:)
      Shiv
        • Re: Macro to delete BOM
          Artem Taturevych
          Check this macro:
              Dim swFeat As SldWorks.Feature
              Set swModel = swApp.ActiveDoc
              Set swFeat = swModel.FirstFeature
              While Not swFeat Is Nothing
                  If "BomFeat" = swFeat.GetTypeName Then
                      swFeat.Select2 False, -1
                      swModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
                  Set swFeat = swFeat.GetNextFeature
              Wend
              Thanks Artem Taturevych....:)
              It's working fine as i want.
              One more problem. I hve bunch of drawings so is there any macro that will action as a batch macro...??
              Thnks,
              Shiv
                  Artem Taturevych
                  You can install myIntercad http://intercad.com.au/myintercad/ and you will be able to find the 'Batch Macro Runner' and 'Batch Macro Runner Lite' utilities under the myToolkit  area (type in filter box) (this is similar to AppStore but all dedicated to SolidWorks). Those are utilities which allow to run specified macro for the files within the specified folder.
                  Note. You do not need to have token or subscription or even register to use myToolkit - just install and use. You will be able to find more macros and other utilities in the myToolkit.
                  Here is the demonstration video of Batch Macro Runner and myIntercad.myToolkit: http://youtu.be/hRg2AfTLbqo
                  Niklas Hellman
                  Could this be tailored to HIDE the BOM instead of deleting it?
                    Cad Admin
                    Artem,
                    Could this be modified to delete revision Table? like maybe using "RevisionTableFeat" instead of "BomFeat"
                        Deepak Gupta
                        Revision Table is a sub feature of the sheet and not the drawing. So you need to use the sub feature codes.
                        Option Explicit
                            Dim subfeat As SldWorks.Feature
                                Set subfeat = swFeat.GetFirstSubFeature
                                While Not subfeat Is Nothing
                                If "RevisionTableFeat" = subfeat.GetTypeName Then
                                    subfeat.Select2 False, -1
                                Set subfeat = subfeat.GetNextSubFeature
                                Wend
                        Wend
                            Cad Admin
                            Deepak,
                            I like yours better...(LOL).
                            I had ended up with:
                            Option Explicit
                            Dim swDoc               As SldWorks.ModelDoc2
                            Dim SwSheet            As SldWorks.DrawingDoc
                            Dim swview               As SldWorks.View
                            Dim SwTableRev        As TableAnnotation
                            Dim swAnn               As SldWorks.Annotation
                            Public currentsheet     As Object
                            Dim mytablerev          As Object
                            Sub Main()
                                Set swDoc = swApp.ActiveDoc
                                Set SwSheet = swDoc
                                swDoc.ClearSelection2 (True)
                                'Selection of the first view
                                Set swview = SwSheet.GetFirstView
                                'Loop on all views
                                Do While Not swview Is Nothing
                                'Search for annotations related to the view
                                Set SwTableRev = swview.GetFirstTableAnnotation
                                'Loop to analyze whether it is a revision table
                                Do While Not SwTableRev Is Nothing
                                    If SwTableRev.Type = swTableAnnotation_RevisionBlock Then
                                    Set swAnn = SwTableRev.GetAnnotation
                                    swAnn.Select3 True, Nothing
                                    GoTo destructable
                                Set SwTableRev = SwTableRev.GetNext
                                    Loop
                                Set swview = swview.GetNextView
                                    Loop
                            destructable:
                                swDoc.EditDelete
                            'insertion table
                            'Set currentsheet = SwSheet.GetCurrentSheet
                            'Set mytablerev = currentsheet.InsertRevisionTable(True, 0, 0, 3, "D:\serv-sec\Solidworks Custom Paths\BOM Template\BOM-STD-VAULT-REV.sldbomtbt")
                            'Attention change the path to the revision table
                            'If true then the table gets on the anchor if not on coordinate 0,0
