I 'm looking for an easier was to model this slot.
First I tried a sweep cut “T” shape as shown in the cross section. Then I added fillets. I wasn’t sure it was accurate and I wanted to use the sketch geometry on the drawing to assist in dimensioning the part.
I then tried a solid body sweep cut over the 4 degrees. The problem here is that I had to do it with a .344 dia cutter and then again with a .500 dia cutter.
I tried to use a “T” shapped cutter but I kept getting a error saying something about a convex body or a revolved body. I was using a revolve body to make the cutting tool.
Can I do this with 1 cutting body?
Can you post your part and cutting tool models?
Cheers,
Anna
