0 Replies Latest reply on Mar 6, 2014 2:12 PM by Chris Johnson
    AngularEquationUnits
    Chris Johnson
      Hi All,
      Im having a little trouble setting the AngularEquationUnits in my macro.
      Here is how im trying to set it:
         swEquationMgr = swModel.GetEquationMgr
              'Set units to degrees
              EQunits = swEquationMgr.AngularEquationUnits = 1
              'add Equation at index 0
              MyEquation = swEquationMgr.Add2(0, """D1@ID Chamfer1""  = " & "((""WALL@LAYOUT""" & " / 2) " & " - .03)" & "/Tan (""D2@ID Chamfer1"")", True)
              If MyEquation <> 0 Then MsgBox("Equation D1 @ ID Chamfer 1 Failed", MsgBoxStyle.MsgBoxSetForeground)
      when i run the macro everything looks fine but when I open the equation manager, I can see that one of them didnt solve and the units are set to radians.
      my question is: is my code incorrect or do i need to set that parameter each time I add another Equation?
      Thank you,
      Chris
