1 Reply Latest reply on Aug 20, 2015 8:29 AM by Marc-Xavier Bilodeau
    Executing a Solidworks vba macro from Visual Basic .net
    Tomate Macarron
      Greetings everyone,
      Don't know if someone has had this issue, but I had a hard time figuring out this, so I decided to publish it.
      I searched the forum and the web and din not find any solution, so I decided to post it here. It may help someone.
      So, if you want to execute a Solidworks vba macro via Visual Basic .net here is the trick:
      Imports SolidWorks.Interop.sldworks
           'This is a button
           Private Sub button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles button1.Click
              'Just to know if solidworks is already opened:
              Dim opened As Boolean
              If Process.GetProcessesByName("SLDWORKS").GetLength(0) > 0 Then
                  opened = True
              Else
                  opened = False
              'Now, this will open solidworks if it is not already opened:
              Dim app As SldWorks = CreateObject("sldworks.application")
              If app IsNot Nothing Then
                  app.Visible = True
              'And the way to execute the solidworks macro:
              app.RunMacro("C:\Users\*******\Desktop\Macro1.swp", "Macro11", "Macro_name")
             'The three string are:
             'Macro filepath name
             'Module name
             'Procedure name
      Best regards.
