I would like to draw a spiral staircase with a central stringer.
But I would like the central stringer is made of rectangular tube.
How is it?
Bonjour,
Je voudrais dessiner un escalier hélicoïdale à limon centrale.
Mais je voudrais que le limon central soit fait en tube rectangulaire.
Comment fait on?
Hi
You can't use weldment functionality with a helix or spline. So you won't get the usual automated weldment details.
If the profile doesn't keep the orientation you want then you may need to add guide curves to key points on the profile.
You could try changing some of the options on sweep function tab....
Roy.
