Hi all,
I happily admit that the UI for applying non-uniform force/pressure is not working well along with my brains, and this together with lack of possibility(?) to verify total loads applied to a face, make me uncertain about the whole aspect of applying loads by this feature. Now I also have this nagging feeling that the units are playing me a trick as well - so now I consider baking bread instead of calculating stress levels and deflections....
I have a 24000mm long structure that shall have linearely varying load beginning with -125N/mm at one end, through zero at midspan, and +125N/mm at the oposite end
(This shall create a moment about the centre of 1,2e10 Nmm = 12000kNm)
I create a coordinate system in the centre of the structure to have the +/- values of the load, but how should the formula/equation for applying correct force look like? And how can i check/verify that the applied (sum of) loads are correct for e.g. each face?
I have tried all variations for "equations" for non-uniform force/pressure I can think of, but the results are so ridicilously far from expected that I suspect there is some flaw in the input load unit / model unit handling.
Anyone exprienced something similar?
I do hope Solidworks come up with a better interface for applying non-uniform loads, and possibility to verify applied load to each face.... Unless someone can enlighten me beyond all my problems here
-a-
"and this together with lack of possibility(?) to verify total loads applied to a face"
calculate the total force of your nonuniform pressure, make a simple part, apply your non uniform pressure, measure reaction force, compare forces to validate. we call this a "smoke test" in our one-on-one mentoring. good habit regardless of what you're doing.
what i find easiest for developing the equation is to start in excel, once you have the coefficients of the equation, its just a matter of plugging them in.
something that might help is start with something that has examples like rho G h for hydrostatic pressure. then you can expand from there.
what would you want to see for a better input method? you can always submit an enhancement request through the customerportal.
