Revision Block has too many lines
Question asked by Bruce Brogden on Mar 5, 2014
Latest reply on Mar 6, 2014 by Bruce Brogden
When I check into the PDMWorks Vault, and the next revision is added to the upper right corner under the old revision (say rev 01, goes to rev 02 on check in), the new rev 02 lines copy the same size as the previous rev 01 block cause huge rev blocks even if there is only one line of test. SO, rev 01 may have 5 lines of text and rev 02 will be the same size, but only have one line of text. This causes the block to be too "tall" and hangs down into the drawing views. Is there a setting in PDMWorks that is supposed to only expand the box for the amount of lines being added? If so, is there a way to correct this issue?
