1 Reply Latest reply on Mar 5, 2014 10:44 AM by Simon Turner
    User property manager page call back
    Kieu Tran
      Hello experts,
      If you know about property manager page API please take a bit your gold-time to help me. I have used SwVBAddin template to create a property page like that:
      Very simple to understand my target. Look at Sample Group I, I chose an option in the combo-box then chose a solid-body in the selection (Selection 1 in the picture), click Apply button then I want to create Case 1 in the list-box. With Case 1 will contain information about name of this option and solid-body (Case 1 is an array, maybe). Then, I chose other option and other solid-body, then click Apply will create Case 2... I know that I have to custome in EventHandling.vb but I don't know how to code exactly.
      And the second question, I have two selection-box with the same selection type (swSelectType_e.swSelSOLIDBODIES). How can I chose same solid-body in all of two selection-box?
      This is my code in UserPMPage.vb
              'Add Controls to Group1
              'group1
              'Combo1
              controlType = swPropertyManagerPageControlType_e.swControlType_Combobox
              leftAlign = swPropertyManagerPageControlLeftAlign_e.swControlAlign_LeftEdge
              options = swAddControlOptions_e.swControlOptions_Enabled + swAddControlOptions_e.swControlOptions_Visible
              combo1 = group1.AddControl(combo1ID, controlType, "", leftAlign, options, "Chose Option")
              If Not combo1 Is Nothing Then
                  Dim items() As String = New String() {"Option 1", "Option 2", "Option 3"}
                  combo1.Height = 50
                  combo1.Style = swPropMgrPageComboBoxStyle_e.swPropMgrPageComboBoxStyle_EditBoxReadOnly
                  combo1.AddItems(items)
              'label1
              label1 = group1.AddControl(label1ID, 1, "Selection 1: ", 1, 3, "")
              'Selection1
              controlType = swPropertyManagerPageControlType_e.swControlType_Selectionbox
              selection1 = group1.AddControl(selection1ID, controlType, "", leftAlign, options, "Displays items selected in main view")
              If Not selection1 Is Nothing Then
                  Dim filter() As Integer = New Integer() {swSelectType_e.swSelSOLIDBODIES}
                  selection1.Height = 30
                  selection1.SetSelectionFilters(filter)
              'Button 1
              controlType = swPropertyManagerPageControlType_e.swControlType_Button
              button1 = group1.AddControl(button1ID, controlType, "Apply", 0, options, "Apply")
              'listbox1
              controlType = swPropertyManagerPageControlType_e.swControlType_Listbox
              list1 = group1.AddControl(list1ID, controlType, "", leftAlign, options, "")
              If Not list1 Is Nothing Then
                  Dim items() As String = New String() {"Case 1", "Case 2"}
                  list1.Height = 50
                  list1.AddItems(items)
              'Group 2
              'label2
              label2 = group2.AddControl(label2ID, 1, "Selection 2: ", 1, 3, "")
              'Selection2
              selection2 = group2.AddControl(selection2ID, controlType, "", leftAlign, options, "Displays items selected in main view")
              If Not selection2 Is Nothing Then
                  selection2.Height = 30
                  selection2.SetSelectionFilters(filter)
      Thanks you for reading!
      Best Regards,
      Kieu Tran.
