Hi Guys,
please help if you can. I am creating a few flat patterns for to be laser cut but when we get all the part back and do the bending, we end up with very different position of our bends.
Laser cuts are correct, our bend guy is very good and always follows the bend linec correctly so it must be the position of my bend lines that are generated by SW.
How and where can I adjust how are all the bend lines positioned?
Please see my file in attach. ( PDF is what I am getting but the face with those 3 holes at the top comes up with different hole position.)
Thank you so much guys.
Fred
Do you have the correct K-factors and bend deductions set in your SolidWorks model that will work with your tooling?
Check out this website for information on how to do test bends to calculate what your tooling needs. Be sure to read the pdf from the website.
http://www.ciri.org.nz/bendworks/
The BendWorks program will help as well.
If you have proper bend deductions set in SolidWorks you will get formed parts that meet print.
Cheers,
Anna
