I want to be able to create the parts I need as bodies in a part file and then export them to a "main" assembly and thereby turning them into parts.
There's already a function called save bodies, that pretty musch does that.
But....
Lets say that I've already exported two bodies to the main assembly, but then create 3 more bodies, that I'd like add to the main assembly as parts and join the existing to.
Is there a way to this?
So I pretty much want export the bodies to the assembly "on the go". I can do this in Inventor, but I haven't figured out how to do this in SW.
Instead of Save Bodies, right click on the body you want to save as a part and select Insert into part. Then place the new part into your assembly.
