Here is something that I am finding some difficulty in putting right.
I have a part model with configurations of which I can modify by highlighting a face and then edit the annotations in the main modelling window without going into the design table.
You will see from the snapshot that the annotations are shown at a reasonable scale.
When inserting this part into an assembly and repeating once again to modify the part (within the assembly), the scale of the annotations/dimensions are somewhat rather smaller.
There is a snapshot of this also.
Am I missing something? I have looked through the forum but with little success so hoping you guys out here have experienced this and know what the solution is to fix it.
Thanks in advance.
Brian
Check the fonts height under Tools > Options > Document properties > Annotation/Dimensions etc. and make sure it is same for both assembly and part. Further update your part and assembly templates to make sure it is set for further use on new files.
