Hello everyone,
I am new in this comunity although I´ve been using SolidWorks for a year. I am trying to maximize the number of rigid assemblies I use, to minimize the number of mates which must be resolved.
The problem comes when the position of some of the parts in one of those assemblies must be defined related to another assembly, so the easiest way would be to set the subassy as flexible and give mates to each of its parts. After I set all the neccesary mates to define each part´s position, I set the subassy to rigid again, willing to keep the parts in the possition defined with mates. But they come back to their original position as if I hadn´t add any smartmate.
Is there any means to "context edditing with mates" the subassy or something so that it keeps the changes when I turn it back to rigid?
This matter is indeed important in cases dealing with high number of parts. I usually have to manage 500 parts which makes everything goes really slow.
Some more info:
Let´s say I have an assy as in PIC2.jpg and I make it to get its geometry as in PIC1.jpg by setting it to flexible. Is there any means to set it back to rigid so it keeps the desired geometry as in PIC3.jpg?.
I also add parts and assemblies I´ve created for this issue.
Thanks in advance.
Luis.
From what I'm seeing, you're not using "true" sub-assemblies. You seem to have some random parts in some sort of semi-random placement. A sub-assembly is, usually, a group of parts that actually fit together (welded, screwed/bolted, etc) that are then affixed to a larger assembly.
To do what you want to do with your 'sub-assembly', you'd need to create configurations. Start with the default configuration, one that allows the bits in it to move around, and have the file open. In your upper level assembly insert the sub-assembly and make it flexible. Position the parts, then switch back to your sub-assembly. If the parts haven't moved around, rebuild it. This should cause the parts to move to the positions that they're in in the upper level assembly. Create a new configuration, then lock all the parts in place. Go back to the main assembly and change that instance to the newley created configuration. You'll need to repeat this for each instance of the sub-assembly in the assembly.
Another method would be to bring the individual bits into the upper level assembly and position as needed. Ctrl+select all the parts, right click and choose 'Form new sub-assembly here'. Doing this will create individual sub-assemblies versus one sub-assembly with multiple configurations.
I would really recommend creating the assembly as it would actually be assembled, though.
