3 Replies Latest reply on Mar 3, 2014 9:29 AM by Ramon F. Herrera
    How would you decide whether to implement an Addin vs. a Macro?
    Ramon F. Herrera
      I just began evaluating SolidWorks and its automation capabilities. Compared with Macros, the structure of Addinis much more complex, requiring registration and many ancillary files, which are generated automatically by templates.
      Under which circumstances would you choose one over the other?
      TIA
        • Re: How would you decide whether to implement an Addin vs. a Macro?
          Artem Taturevych
          Currently you have a very big choice. In addition to COM based add-ins and VBA macros it is also possible to write macros in C# and VB.NET as the VSTA macro just inside the SolidWorks. Previously some developers prefer add-ins due to above fact but now it is no longer the case. You can also write stand-alone applications in any language (http://www.youtube.com/watch?v=aoXJGKAwhbc).
          I would list advantages and disadvantages of all approaches. This is my view only. Someone can have different view.
          Feature\Method
          VBA Macros
          Add-ins
          VSTA Macros
          Stand-Alone
          Comment
          Easy to start
          Yes
          No
          Yes
          Yes
          Average time spent for a not experienced user to start a solution
          Easy To Deploy
          Yes
          No
          No (should be easy but in practice usually a lot of problems)
          Yes
          Time spent to make your software work on another machines
          Protected Code
          No (only password protection)
          Yes (binaries)
          Yes (binaries)
          Yes (binaries)
          A ways to IP protect your code
          Scope of available Utility Libraries
          No (only obsolete VB6 libraries)
          Yes
          Yes
          Yes
          Availability of utility functions for working with Databases, Files, XML etc.
          Scope of available SolidWorks functions
          Limited
          Full
          Limited
          Limited
          Some interfaces will only operate within the add-in such as the ones from SWPublished library
          Reliability
          No (usually the problems with missed libraries etc)
          Yes
          Yes
          Yes
          How much the solution is reliable across the SoldiWorks versions and PC workstations.
          Debugging
          Easy (out of process)
          Complicated (in-process). Slow to restart because requiring to restart add-in/SolidWorks
          For in-process applications it is not possible to see and change SolidWorks at runtime from UI.
          Requirement of additonal software
          No
          Development IDE required
          No
          Development IDE usually consist of code text editor and compiler (e.g Visual Studio, Eclipse, CBuilder etc.)
          User Friendly for the beginners
          Yes
          No
          No
          No
          Performance
          Normal
          Good
          Good
          Normal
          Operating performance
          So, as the summary. There are 3 major factors which influence of what approach to use: the type of task, level of experience, software availability.
            Roland Schwarz
            Addins let you do some things that macros don't
            • Run in background without added drag
            • Detect events (e.g. file save, selection) while running in background
            • Add menus, toolbars, RMB-click menus
