I'm looking to use a part file as a skeleton model and then export the bodies I create, to an assembly and thereby converting them to actual parts, plus having a main assembly.
I've been experimenting with the save bodies function, which works fine, untill the point, where I have more bodies that I want add to the main assembly.
Maybe there another way to do this, I'm all ears...
Hope someone can help.
John,
I don't understand what problem you are having. What happens when you "have more bodies that I want to add to the main assembly"?
Jerry S.
