I'm seeing an issue with my part files that I have created using the split feature.
After splitting the part and saving off the bodies, all my custom properties are entered in as "fromparent+" (see image).
Regardless of how I use this command (for example without copy custom properties selected), once the parent part has been opened and modified, this "fromparent+" overrides whatever new custom properties I have added to these new split body parts.
My Var cannot help me out with this issue. I'm wondering if anyone else has seen this issue and found a way to stop it?
I've ended up writing a macro just to continually re-enter the custom property information that should be in there.... which takes care of the issue, but is only acting like a bandaid to problem.
The best solution I was suggested by my VAR just last week was this:
1. Don't use the split command to save out the body
2. Instead, use the 'insert part' feature in a new part
3. then go in and delete the bodies you no longer need in this new part.
This takes care of my issue as long as I don't add any further features after the split command on the master part - which is never.
