Workgroup PDM API hang-up
Question asked by Peter Stroh on Feb 27, 2014
Latest reply on Jan 9, 2016 by Peer Larson
I am writing a macro to grab pdfs from vault and put them into a network folder at check-in. I am heavily borrowing code from the numerous workgroup pdf macros, namely the one found here: https://forum.solidworks.com/message/264677
The problem I keep running into is the macro freezes and solidworks freezes at the same line of code. Below is the basic starting structure of the code:
Option Explicit
Dim swApp As Object
    Dim connection As PDMWConnection
    Set connection = CreateObject("PDMWorks.PDMWConnection")
    connection.Login "xxx", "xxx", "xxx"
    Dim alldocs As PDMWDocuments
    Dim doc As PDMWDocument
    Set alldocs = connection.Documents
The code consistently hangs up and freezes on the red bolded text, when I've seen other people say that they can run the macro to export their entires vaults pdfs in under a minute. Does the size of our vault make a difference? Does anyone else experience this hang-up?
