Is there a way to set the date format to show up like this: 26-JAN-14
I want to add a date variable in a template and it looks like the only option is the month abbreviated as: Jan instead of JAN
I also went into the Windows regional settings with no luck on this format either. Is there any other way to do this?
Kim,
It doesn't look like it, as far as I can see you can't even get regular dates to show up in this format. You could probably get an add-in to do this if you set it to trigger on file add, but that would be a fair amount of work if you're not familiar with coding add-ins.
