I am new the whole sheet metal world. Thecompany I work for is starting a fab shop and im trying to build asmany parts in SW as i can before we start production. I know thatthere will be alot of trial and error thing that will happen, and iwill learn alot from this as well. I am looking for advice orsome general rules that people go by when assigning or determininga bend radius. All our parts will be from 12-18 ga mostcommonly. Thanks for the advise.
Internal bend radius is usually dependent on the size of the Vee that is used.
The vee that you use depends on the minimum radius the material will support without splitting and the maximum pressure that the press can deliver.(bigger radius = less pressure)
You may have some data that you can use that is supplied from your press brake supplier.
If not you may need to find out some bend deductions for your material by either pressing some material to 90 deg or entering the parameters into your press brake controller.
You can then use the thicknesses, bend deductions, and internal radius dimensions to extrapolate the K factor for your materials.
K factors have the advantage of being independent of the angle of bend used.
Finally you could then tabulate all the results into a bend table
